Thread: New AG Pool Install - Green water
    Nov 2015
    Iota, LA
    4
    I just had a new 27' above ground pool installed this weekend. I filled up the pool from my water well over the course of 36 hours. The pool turned green before I could even finish filling it up. My test results are as follows:
    FC - 0
    CC - 0
    pH - 7.2
    TA - 250
    CH - 75
    CYA - 0
    This morning, the pool was full, so I turned on the pump and, after obtaining the above test results, I mixed 2 packs (1 pack per 10,000 gallons) of calcium hypochlorite in a bucket of pool water and dumped it in next to the return.
    I understand that the calcium hypochlorite will add both chlorine and stabilizer to my pool.
    Is it expected that on an initial fill that the water would already turn green?
    Based on my test results above, is there anything else that you recommend that I do to get my water right?
    What should I do about my high TA?
    The TF-100 does not test for iron levels. The water that I used to fill the pool did come from a well, but went through a water softener. So, the majority of the iron should have been filtered out. But how would I test for that if the TF-100 doesn't include that test? Is there another recommended test kit that I should by that will test for iron?
    I stumbled upon this forum during my pool research late last year and decided to start my new pool following the guidance the trouble free pool forum. Thank you so much for your help.
    27' round AG, 19,300 gal, 2 HP 2-speed pump, cart. filter, Installed on 5/15/2016, TFT TF-100 Test Kit, water sourced from well
    triptyx's Avatar
    Apr 2016
    1,438
    Re: New AG Pool Install - Green water
    Calcium Hypochlorite adds calcium, not stabilizer. If you're going to use cal-hypo, you'll still need to buy and add stabilizer.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Nov 2015
    Iota, LA
    4
    Thank you for clearing that up for me. I must have misread something that lead me to believe that it also added stabilizer.
    Do you have any recommendations on what I should do about my high TA?
    Any recommendations on test kits to test for iron and/or other metals in my well water?
    triptyx's Avatar
    Apr 2016
    1,438
    There's a great article about high TA here:
    Pool School - Lower Total Alkalinity
    I'll leave it to someone more experienced to discuss what your "target" should be. It's a relationship between natural rise in Ph and your TA level.
