Thread: Big Leak After Opening - :( urgent questions
    Jul 2008
    Denver, Colorado
    98
    Hey All,
    Pulled the auto cover back to see the water level line midway up the skimmer. I have not been in this house for two seasons now so was worried that winterizing from 2014/15 was no longer 'solid'.
    Had filter running over night after performing a SLAM process and I've woken up this morning to see the water level at the base of the skimmer plate. Believing that the skimmer was the problem and I had a crack somewhere, I carried on my day to now look again and it has dropped a further two inches.
    For some reason, I seem to remember my pool may have had an issue with the Hydrostatic Valve from the season in 2014.
    Any advice on where to go with this? Water is freezing cold so replacing at present is not my favorite option
    I have now blocked off the drain return in the skimmer (only have two holes - one to drain, other to pump) and winterized that line by blowing and capping.
    Will the water continue to drain?
    If that is the problem, Can I refill keeping that line closed permanently until I replace the liner?
    Can you replace a Hydrostatic Valve with water in the pool? (pool company said I couldn't)
    This is an inground vinyl pool. wrinkling on the liner is happening in the shallow end on the walls so wondering if they will come out
    I did do a drip test of food coloring around the returns, light and skimmer. Nothing obvious and the water is too cloudy to see the drain to inject at depth without being in it and submersed (brrr!)
    This cannot be the main skimmer to filter line as water level has now dropped below this.
    Why did this not empty when system was off?
    Any quick advice greatly appreciated to save the liner and water already in it.
    Dannyboy
    25k Inground Vinyl - 3ft to 10ft, Tagelus TA-60 Sand, Minimax 400 Heater, Save T3 autocover.
    Jul 2008
    Denver, Colorado
    98
    Re: Big Leak After Opening - :( urgent questions
    Found it whacking great rip in the liner...
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Oh, that sucks. Any idea on the age of the liner? Small pin holes before winter can cause the liner to fail over winter.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jul 2008
    Denver, Colorado
    98
    It's 9 years at least. I can see a long tear in it. Is there a limit on the length that's 'patchable' and is it covered under home owners insurance? (long shot)
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    If someone else doesn't come along, I would post a new question so you get a better response. Make sure to include a pic and the length of the tear.
    I'm no expert, but I hear they last between 8-10 years depending on how well the pool is cared for (PH, FC with CYA recommended levels). The UV light also degrades the liner.
    Karen
