Thread: R-0871 shelf life
    Jul 2010
    Double Oak, TX
    44
    R-0871 shelf life
    I'm curious. Is there shelf life for the various chemicals we use for testing our pools? I have a 2oz bottle of the R-0871 I ordered from TFTestkits. I think I am in my second season using it. I have lost confidence in the results reported on the chorine tests. I have run these tests often enough & long enough that I can eyeball the range between .5-2 ppm of chlorine. But when I add R-0871 to the mixture created with R-0870, the ppm results reported are generally double expectation. Same is true, of course, after adding chlorine amount recommended by PoolCalculator.
    I store my test kit indoors, with the exceptional overnight error.
    Thanks.
    35K gallons, StaRite S8D110 DE Filter, Pentair IntelliFlo vs3050 pump, IG gunite
    38,475
    Re: R-0871 shelf life
    I have never seen any reagents go bad, you should be able to get 2 seasons it of them. Tftestkits had an 18 month guarantee.
    I would just forget about the color matching test.
