Thread: Any tricks to removing a tight pool jet return fitting?
    Apr 2016
    Youngsville, LA
    274
    I have two return jets that need to be adjusted and they are stuck in there pretty good. I was going going to try some channel locks, but I figured I'd ask you guys opinions before I mess them up. I was also thinking about using one of those rubber lid grips that people use in the kitchen. Any tricks to loosen it?
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin Nautilus Plus Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Any tricks to removing a tight pool jet return fitting?
    I would start with one of those rubber grips, then move to channel locks over those rubber grips, it should not take to much pressure to remove just torque
    Jul 2012
    Cary, NC (Raleigh)
    69
    Auto Oil filter wrench. Its a "rubber" wrench but probably a bit more industrial than the type used to open can lids. Also pretty cheap at most auto parts store.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Strap wrench. One with a rubber strap works best. Move to channel locks only if you have to. They are much more likely to do damage.
    chiefwej
