Thread: Very low pressure on gauge
    Jun 2014
    Bloomington (Minneapolis), MN
    110
    Hey all, looking for some feedback on an issue I'm having with my pressure gauge. It has been reading around 3 psi ever since I replaced the motor end of my pump (same horsepower, just a generic motor). I knew the filters were old so I thought it might just be them causing it.
    I ordered a new guage thinking it might also be bad. I installed new cartridge filters along with the gauge. The new guage is still reading 2-3 psi.
    The weird thing is I'm getting very good pressure from the returns and my booster pump/cleaner are working fine.
    Any ideas on what's going on?
    Pool: 28K gal, vinyl lined, rectangular, auto cover
    Equipment: Mineral Springs MS-10 SWG, Raypak 266A heater, Jandy CL460 cartridge filter, Pentair superflo 1hp 2spd pump, Polaris PB4-60 booster pump and Polaris 280 cleaner. TF-100 w/speed-stir
    Jun 2014
    Roseville, CA
    343
    Re: Very low pressure on gauge
    Assuming it's on the filter housing, have you bled the air out?
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    30,421
    What was your normal psi prior to the changeover?
    Jun 2014
    110
    Quote Originally Posted by Chuckiechan View Post
    Ya, I left the valve open until water started coming out and then closed it
    Jun 2014
    110
    It was in the high teens/low 20's with the old motor and filters. I did use Teflon tape on the threads, that wouldn't mess anything up would it?
    30,421
    Possibly. If the teflon restricts the water from actually entering the gauge by over lapping the orifice, that might do it.
