Thread: Bonding wire between booster and main pump
    Jun 2013
    Boston, MA
    91
    Hi - I think the answer is yes, but i just want to confirm. I have a bonding wire that can reach the main pump, but the wire is not longer enough to reach the booster pump. Can I just get a copper wire, attach it to the booster pump and then connect it to the lug on the main pump where the bonding wire is?
    Thanks!
    Inground pool; about 20,000 gallons (18' x 36'); pool liner (vinyl?) a few years old; Hayward pump SPX2607X10
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,775
    Re: Bonding wire between booster and main pump
    yes, it should be at a minimum 8awg bare copper wire. Where the wire is spliced you should use a split bolt connector like this one. http://www.homedepot.com/p/Blackburn...B2-5/100165861
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Apr 2013
    Sacramento, CA
    2,769
    +1 to CJadamec.
