Thread: Identifying old pump
    May 2016
    Yardley, PA
    3
    Hi,
    I am trying to identify this pump so I can replace the seals using the great info I found on this forum. See photos and let me know if anyone has any clue. Trying to save a couple hundred bucks by not replacing this. It runs fine it just leaks out the bottom.
    May 2016
    Yardley, PA
    3
    Re: Identifying old pump
    Does the "SP2600-B" identify the model I should be searching for?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    A google search of the part number on the diffusor housing says you have a Hayward super pump, 2600 series. You should be able to find a seal kit for that pump without too much hassle.
    Also check that tag on the motor if its the original motor it may have the pump info on it too.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2016
    Yardley, PA
    3
    I did not notice that number until I posted the photo, duh. I was looking all over the outside of the pump and motor for info on a label. THanks!
