Thread: tri chloro cya question
    How much cya does each tab of tri chloro add to the water by volume? has anybody done any studdies on this?
    Just a thought. thanks
    18 X 36 IG Vinyl liner 3' shallow 8 ' deep end
    Hayward 1.3/4 pump and hayward 300lb sand filter
    Aquarite SWG system
    location Southern Mississippi
    Water from well
    Guest
    Re: tri chloro cya question
    For every 10 ppm of FC added by trichlor you have also added 6 ppm of CYA. Since there is no standardized size for trichlor tabs it's impossible to say how much one whole tab will add.
    If you look at the bottom part of the pool calculator (link in my sig) it will tell you the effects of adding various chemicals to your water.
