Thread: Concerns about equipment noise level and location
    May 2016
    Lake Forest, IL
    3
    In general, how far do people recommend having pool equipment in relation to patio/entertaining space? We are thinking about moving our equipment from a location literally in the middle of our yard approximately 25 feet behind the pool (unsightly fenced in box), to either the HVAC location next to the house or closer to the side of the lot still behind the pool. The HVAC location is currently 8-10 feet away from the patio and pool deck, it also shares a brick wall with our family room. Generally are people concerned with the sound level of the pool equipment? (Sand filter/heater/pump/etc)
    We have had mixed reviews from pool builders regarding whether this would be an issue or not.
    Jan 2016
    TX
    157
    Re: Concerns about equipment noise level and location
    Quote Originally Posted by Poolinthe45 View Post
    My 3HP pump running at 3000RPM isn't as loud as my HVAC. However... my pool equipment is on the side of my house near my patio area ~15ft and I wish I could have located further away. In the grand scheme its not a deal breaker for me as the cost to located it on the far side of the house was too much and I wouldn't have wanted it in the middle of the yard boxed in.
    Gunite Pool/Spa, CLI Caribbean blue crystal stone smooth, Pentair 3hp Intellifo VS, Pentair Quad DE Filter, Pentair 400k BTU Heater, KK Prowler 820, Pentair PSL4 controler with Screenlogic wifi, Inline Chlorinator, Pentair 1.5hp Spa Blower, TF-100 Test Kit w/ Speed Stir. My 2016 Pool Build
    Jul 2015
    Central Valley CA
    1,107
    My VS pump at 1100 RPM almost can't be heard and it is right next to the house. Running at 2200 with the booster for the polaris is a different story but that is only 30min a day and not while we are home so no problem for me, not sure about the neighbors take though (I am sure most of them are at work too when we run it)
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2013
    Sacramento, CA
    2,769
    My pool pump is right behind my dining area and with the waterfall on you never notice it. Even the solar speed isn't really noticeable.
    May 2015
    Land O Lakes, FL
    527
    My Pentair Intelliflow is just about 15 from the water of the pool and just a bit off of the house corner. As already said, even at the highest sound level it is not as loud as the AC and especially when 2 of them are running. I would worry more about ascetics from a location perspective than the sound.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
