Thread: Help replacing jandy 2444 actuator
    Dec 2010
    El Dorado Hills, CA
    75
    I've been reading over the jandy manual for 2 hours and am having trouble understanding something.
    https://www.poolzoom.com/index.php/f...382560673.pdf/
    It says:
    1) the smallest slot on the output shaft is directly above the valve diverter
    2) upper cam stops counter clockwise position
    3) bottom cam stops clockwise position
    I understand steps 2 & 3.
    What do they mean by step 1??
    Ed
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Help replacing jandy 2444 actuator
    If I recall correctly there are 4 slots around the shaft of the Jandy valve. One of them is thinner than the other three and that one is where the OFF tab points.
    Dec 2010
    El Dorado Hills, CA
    75
    So I simply need to turn it so the small slot points where it should be off before setting the cams? How do I turn it?
    DFW, TX
    24,514
    Physically rotate the actuator until it drops down on the valve and then set the cams.
