Thread: Need help patching mortar between coping stones
    Jun 2015
    Dobbs Ferry, NY
    13
    Can anyone direct me to a product or process, or link to a conversation about patching / replacing mortar between (not behind) coping stones? I will post a few pictures to show what I'm dealing with.
    Much obliged for any help.
    Thanks!
    36k gallon in-ground gunite / Sta-Rite Max-E-Therm 333 / Century 1HP Motor B228SE / Pentair Triton II sand filter / Polaris 280 sweeper
    Jan 2016
    Mesa, Az
    541
    Re: Need help patching mortar between coping stones
    Did they use pointing mortar or grout? Go buy a small Makita grinder and a diamond wheel. CAREFULLY grind out the joint, brush it out well and repoint with same material as originally used.
    30,431
    How old is the existing grout? How many voids do you have?
    Jun 2015
    Dobbs Ferry, NY
    13
    There are probably three with large voids, and another two where it is cracked bad enough that I should knock/grind it out and redo. How can I tell if it is pointing mortar or grout?
    Thanks for the replies!
    Jan 2016
    Mesa, Az
    541
    Is it the same color as your tile grout or more generic gray, like mortar? They could have set the coping and grouted same as the tile, or they could have buttered the edges with mortar when they set the coping. Either way, you want the repaired areas to match somewhat close to the ones you aren't touching. You never get a perfect match due to age, but close is nice.
