Results 1 to 9 of 9
Thread: Weird question
    natedogg's Avatar
    May 2016
    Warren MI
    22
    Weird question
    If your pool is set up with a SWG can you turn it off and run the pool as a non SW pool?
    Square 19,000 gallon in-ground pool
    cartridge filter
    SWG
    intelliflo vs+svrs
    K-2006
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: Weird question
    Yes. No reason you can't. Just need to consider lowering CYA if it's up at SWG level and make sure you are using the proper chart.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    natedogg's Avatar
    May 2016
    Warren MI
    22
    Re: Weird question
    thanks, I'm not sure if there's an issue with the system and figured worst case scenario I could bypass the SWG. Appreciate the insight!
    cartridge filter
    SWG
    intelliflo vs+svrs
    K-2006
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Weird question
    My SWG while also on a timer can be turned on and off independently when I desire.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Weird question
    Sure, I use bleach regularly to supplement my SWG during pool parties and busy swimming weekends. I also turn off my SWG when the temp gets down to 70 in the fall and switch to bleach until the temp gets back to 70 in the spring.
    natedogg's Avatar
    May 2016
    Warren MI
    22
    Re: Weird question
    Appreciate the insight! Just filled the pool and started the pump so I haven't been able to test the water. I had a guy clean and open the pool since it's the first year I've had it, is there a time I should first test the water?
    cartridge filter
    SWG
    intelliflo vs+svrs
    K-2006
    Aug 2014
    Northern IL
    4,615
    Re: Weird question
    Wait a couple of hours so it circulates well; then test. What kit do you have? Don't see it in your signature.
    natedogg's Avatar
    May 2016
    Warren MI
    22
    Re: Weird question
    I bought the K-2005 and got the test the site recommends to make it a K-2006. I have a SWG that is showing no flow so I may not want to fix the SWG if the cost is going to be too high. I see mixed reviews on them and am curious if people feel it's worth repairing SWGs. Seems like a lot of work to address the issue.
    cartridge filter
    SWG
    intelliflo vs+svrs
    K-2006
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Re: Weird question
    Since opening my SWG is been off I'm using bleach
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
