Thread: ? about rainbow 820 inline chlorinator
    May 2016
    Boerne, Texas
    5
    New pool build here. I was going to put some trichlor tabs in my chlorinator.
    I have followed the instruction on the chlorinator but the water level never drops in the chlorinator. My pool equiptment is below the water level of my pool so I wonder if the back pressure from the water column in the pipes prevent the water level from dropping? This seems to be correct because if I turn the knob up from zero on the chlorinator while the pump is off water starts coming out of the top of the chlorinator.
    Is is still safe to drop tabs in there if the water level never drops?
    Thanks in advance.
    IG Stonescapes black plaster pool w/ spa. Don't know the volume, gotta figure that out. 2x 3HP pentair inteliflo VS pumps, Pentair sand filter, Mastertemp 400k NG heater, Pentair automation, city water (San Antonio,TX). K-2006 test kit.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: ? about rainbow 820 inline chlorinator
    There really isn't any reason to put tabs in the chlorinator. Just use bleach. That way you aren't adding stuff that you are going to have to drain to remove.
    TPFC is all about using simple stuff you get from the grocery store.
    I suggest you take a look at this page and let us know when you are ready to start enjoying pool care the TFPC way.
    Pool School - TFP Home Page
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2016
    Boerne, Texas
    5
    Appreciate it. I've read it all. But that doesn't answer my question.
    Figured it out. Looks like they need to install a drain valve if installed below the water line.
