Anyone make a solar cover reel system for a 30' round ABG?
doc8404
473
Rome, NY
Appears no one sells anything for this size pool. I would need a system that would not be bolted to the coping either. In the end, I am thinking it would be mounted on a swivel from a 4 x 4 in the ground, across the pool and onto another 4x4 as you use it, and then back into position.
they do but you will need to "modify" it :) just like your thinking or you can get longer straps and connect them to the middle of the solar pad...
Both ways are not the best or easiest option, but they work in a way :)
thanks for the reply...found the big "hooks" or "holders" that also attach to the pool and you roll it up manually and push over the side and store it there....better than on the ground, dirt and sand as now but those have to go over the edge of the pool...not ideal. will keep hunting.
