Thread: Anyone make a solar cover reel system for a 30' round ABG?
    Sep 2015
    Rome, NY
    363
    Appears no one sells anything for this size pool. I would need a system that would not be bolted to the coping either. In the end, I am thinking it would be mounted on a swivel from a 4 x 4 in the ground, across the pool and onto another 4x4 as you use it, and then back into position.
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Anyone make a solar cover reel system for a 30' round ABG?
    they do but you will need to "modify" it just like your thinking or you can get longer straps and connect them to the middle of the solar pad...
    Both ways are not the best or easiest option, but they work in a way
    Sep 2015
    Rome, NY
    363
    thanks for the reply...found the big "hooks" or "holders" that also attach to the pool and you roll it up manually and push over the side and store it there....better than on the ground, dirt and sand as now but those have to go over the edge of the pool...not ideal. will keep hunting.
