Thread: Rubber Coupling
    Mar 2013
    CT
    349
    Rubber Coupling
    Hi
    Would this be ok to use on my return?? Im just wondering from a pressure standpoint.
    It originally had a barb ABS Coupling that pushed into the black ABS tube in the ground ut that cracked so i hsd to find something else. It works and best of all doesnt leak. Maybe im over thinking which I have been known to do but is this ok to use rather than the ABS piece that was previously on there?
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    22,543
    Re: Rubber Coupling
    What does your pressure normally run?
    I think it'll be fine, but keep an eye on it, as that black polyethylene pipe is kinda slick and you don't want the rubber coupling slipping off it.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,754
    Re: Rubber Coupling
    It will work and it may work for a long time but its always going to be at elevated risk of popping off when you least want it to be. A proper barb fitting there would be best there long term.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mar 2013
    CT
    349
    Re: Rubber Coupling
    Thanks! I'm replacing it today. I don't trust it since it's obviously the weakest link. Plus I'm thinking the UV rays from the sun will eventually dry it.
