Thread: Completed hard piping Intex pool (pics)
    Mar 2016
    Wantagh, NY
    32
    Just wanted to say thanks to everyone on this website who helped inspire me to upgrade my Intex 14X42 pool.
    Parts I used:
    Intex 2650 sand filter
    1.5" Intex Inlet and strainer
    Intex plunger valves
    Hayward 1091LX skimmer.
    My pool originally had the pump and hoses facing towards my deck, but I ran a new electrical outlet to the opposite side of the pool by my fence so you cannot see any hoses or equipment, I ran 1/2 PVC underground from the fence to under my deck where I had existing power.
    The skimmer was nerve racking to install, but it came out great, and no leaks.
    I now have a crystal clear pool.
    https://photos.google.com/share/AF1Q...9FNEpEZFkyR1hn
    Casey's Avatar
    SW PA
    10,448
    Re: Completed hard piping Intex pool (pics)
    Great job!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    That is a great looking setup there
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Neat and clean... 😊
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Mar 2016
    Wantagh, NY
    32
    Thanks.
    Also forgot to mention I did make up the box adaptor connections to attach to the plunger valves, and to the pump.
    I did not use any unions, but in one location, below the skimmer, I did use no-hub coupling for easy removal. Also I think it adds a little cushioning and play for the skimmer to move a little when the pool is in use. I think if left rigid, it would put some strain on the liner with a lot of movement.
    jmcdtucson's Avatar
    Jun 2014
    317
    Very nicely done! Hard plumbing is so much better.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
