Thread: EUREKA!!!!!! Now help me not screw it up!
    May 2016
    Atlanta, GA
    89
    We drained the pool...again. And we now have a CYA of 50!!!!!!!!!!!!!!!!!!!!!!!!!! However, in doing so we seriously tweaked the rest of our chemicals.
    FC - 3.5
    CC - .5
    PH - 7.2-7.5
    CH - 155
    TA - 50
    CYA - 50
    Pool math recommends the following:
    38 ounces of 10% bleach
    187 ounces of CH
    56 oz of baking soda
    So here are my questions...
    1. A stupid question because I never did good in math. When it says 187 oz by weight or 149 oz by volume it means you would use a scale for the first one and a measuring cup for the second correct?
    2. In what order do I add these items?
    3. How long do I wait between adding chemical types?
    Thanks!
    KG
    14.5'x32' irregular shape Pebble Tec SWG pool; 12,000 gal; Purex Triton Tagelus Sand Filter; Pentair IntelliPh Ph Controller
    38,284
    Re: EUREKA!!!!!! Now help me not screw it up!
    What does you water look like?
    1. Yes
    2. It does not make a lot of difference. FC first, then the CH, and baking soda. I would not raise the TA above 80ppm.
    3. 15 minutes is likely plenty.
    May 2016
    Atlanta, GA
    89
    Water is crystal clear!!! We have stains again which means we basically wasted that entire month of treating them but they are not as severe and at this point we will take them just to have normal chemical levels again!
