Results 1 to 18 of 18
Thread: 50,000 gallons and TA is 230 this am
    HELICOP's Avatar
    May 2016
    Denver/Colorado
    5
    What a fantastic site. Too bad in took me 2 years and lots of $$$ before I found it. I went to the DIY store and built the aerator inspired from Rangeball back in the day ( you can find it here on TFP - search for "my aerator"). I also pick up a couple go gallons of muriatic acid. It took 2 hours to build the aerator because I am slow. No glue necessary, all fittings held through PVC pipe pressure and it is actually is working. I will post a pic in about 5 mins. Total cost = $30.
    Here are my numbers as of this morning:
    pH 7.2
    CH less than 1 --- just converted this year to a SWG that is not keeping with my demand yet. I have shocked twice in the last 48 hours and adding CH tablets in skimmer to help until the SWG kicks in.
    TA 230
    CYA 100
    So, the plan is to aerate the water until TA comes back with acceptable limits and use the acid to lower pH as needed. Am I on the right path other than needing a lot more Chlorine?
    20x50 IG Vinyl Liner / 50k gals, Pentair Superflo (1.5 HP Pump), Pentair Triton II Sand Filter, 400k BTU Heater (Rheem), Pentair Intellichlor (SWG) , Automatic Cover (pending) - just got bid, 2 Skimmers, 4 Return Jets, 1 Drains
    2200 sqft of Stamped/Textured/Colored Concrete, Diving Board
    38,547
    Re: 50,000 gallons and TA is 230 this am
    Welcome to TFP!!
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    Water Balance for SWGs
    Note that CH here means Calcium Hardness. What are you testing your pool with?
    You CYA appears to be too high and if the SWG can not keep up, it must be due to something in the pool. To fix that, you might need to replace some water and then follow the ShockLevelAndMAINTAIN Process.
    Forget about the TA right now and focus on getting the water back under control and safe. TA is about the last thing to worry about.
    HELICOP's Avatar
    May 2016
    Denver/Colorado
    5
    Thank you for the quick reply. I'm using a Taylor K - 2005. I will focus on shock, level and maintain process.
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Your test kit is devoid of the most important test we need: The FAS-DPD test which tests FC up to 50ppm.
    You can order it individually and it will make your kit equivalent to the K-2006 kit we trust.
    TFTestkits.net is the site to order it from TFTestkits.net
    HELICOP's Avatar
    May 2016
    Denver/Colorado
    5
    Roger. Ordering now. Thank you.
    Aug 2014
    Northern IL
    4,615
    Perfect on getting the FAS-DPD test! Redo your CYA test with the dilution method. Here are the instructions: Pool School - CYA
    Apr 2016
    NC
    109
    I have the K-2005 it will work. However the titration method, which is what you just ordered, is superior in every way. When my reagents run out I will order the ones for the fas-dpd. However, either will work it is just a matter of ease and accuracy. I got mine for such a good deal I couldn't pass it up.
    GL with the slam I am still in process on my swamp and am 2 weeks strong. Post some pics when/if you can.
    Thanks
    Jared
    33k IG Gunite, Hayward T-15 Cell SWG, Hayward Sand Filter S210T , Pump Wisper Flo 1.5 HP, Test Kit K-2006
    Aug 2014
    Northern IL
    4,615
    The OTO will not give you an accurate result above 5ppm. It's just a guess after that. The FAS-DPD goes up to 50 ppm.
    Apr 2016
    NC
    109
    K-2005 has the DPD test not the OTO based on everything I can find on the net. Please correct me if I am wrong.
    Jared
    Aug 2014
    Northern IL
    4,615
    You are right. The DPD in the 2005 goes to 10ppm.
    38,547
    Quote Originally Posted by MarianParoo View Post
    If you can differentiate the shades of pink. As stated above the FAS-DPD is far superior.
    Aug 2014
    Northern IL
    4,615
    Amen. Wouldn't want to test without my FAS-DPD!!!
    Helicop: let us know the results of your CYA dilution test.
    Apr 2016
    NC
    109
    I think it'll do 40 ppm with correction factors, I will be glad when I trade up though 😀.
    HELICOP's Avatar
    May 2016
    Denver/Colorado
    5
    I will post the results the day my kit arrives. It has already been shipped. Thank you all.
    Aug 2014
    Northern IL
    4,615
    Great! You can do the dilution test with the 2005, btw. No need to wait to know where your CYA is.
    HELICOP's Avatar
    May 2016
    Denver/Colorado
    5
    Ok everyone. New kit arrived today. Here are my numbers.
    FC - .5
    CC - 1
    PH - 7.6
    TA - 190
    CH - 550
    CYA - 100
    Let me guess, drain the pool to get CYA within acceptable range 80 or less and then incorporate SLAM. Sound about right?
    38,547
    Sounds like you got it
    Might try the CYA dilution test to see how far above 100ppm it might be.
    Aug 2014
    Northern IL
    4,615
    Do the CYA dilution test linked below to determine how high your CYA really is. Let's go from there.
    Pool School - CYA
