Results 1 to 13 of 13
Thread: First test after resurface
    estrda1's Avatar
    Nov 2009
    Riverside, Ca. (SoCal)
    33
    My pool resurface was completed yesterday and finished filling up my pool this morning. The company doing the job isn't going to be able to stop by until tomorrow morning but they assured me that I can go up to a week without chemicals. That made me feel concerned though because everything I've read states to begin working on the chemicals and brushing ASAP. Anyways here are my current reading using the Tf-100 Kit. I am hopeful they will change in the right direction tomorrow after the pool is looked at. Right now I am running the pump and will brush it twice today with a nylon brush, company discouraged a combo brush and said nylon only for now. I stopped by Walmart and bought some borax and baking soda. I have several gallons of acid and a bag of conditioner (99% CYA). Should I add some stuff today or wait until tomorrow. I plan on maintaining it after the 2 sessions the company is providing with the resurface contract.
    FC- 1
    CC (Chlorine Drop Test?)- 1
    pH-8.2
    TA-270
    CH-150
    CYA-100
    My 05/2016 resurfaced pool: 16ft x 24 ft irregular w/spa, 20K gal., gunite Stonescape Aqua White mini pebble. Not a salt water pool.
    Equipment: 3hp Intelliflo VS pump, Hayward C4020 4 cartridge filter, Hayward H series heater, Pentair Intellibrite 5g LED lights,Dolphin Nautilus Plus robot, TF100 test kit.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: First test after resurface
    Hold on boss... you got those readings from a newly filled pool?!?
    How'd you get CYA of 100 already???
    estrda1's Avatar
    Nov 2009
    33
    I may have gave wrong reading. I assumed because the water did not obscure the black dot with a filled tube that it was 100. Like I said water was clear after the test. Ian now going to assume its 0.
    Jan 2012
    7,264
    Ok, <whew!> that is zero....take note how the numbers go up/down on that tube.
    Here is a good start: Pool School - Start-up New Plaster
    Get in to Pool School (link at top right of this page) and play around with PoolMath for amounts of chemicals you'll want to add.
    estrda1's Avatar
    Nov 2009
    33
    I will, thanks. So after reading the article I will have to keep the pump on 24 hrs a day for seven days correct? Is that also at full speed or a different lower rpm? Also, should I add a sequestrant? Not sure about the amount of metals if any in my tap water but some advise to put it just in case and others feel there is no need to add it if just to be safe if there is no need for it.
    Jan 2012
    7,264
    I checked with one of the Experts here about the sequestrant use in new plaster start ups. This is what Joyfulnoise said:
    "Typically one adds sequestrant at startup as a calcium scale inhibitor because most of the phosphonate based chemicals are good at binding calcium. The addition of sequestrant is "insurance" against random calcium scale patches."
    estrda1's Avatar
    Nov 2009
    33
    Thanks for those that are chiming in. I was at work while the builder had a pool guy come by and put some chemicals in and clean the filter. I also decided at the last minute last night and poured some sequestrant in the pool just in case. The pump has been on and will stay on 24 hrs. a day for the next week or so. It is at 1750 rpm for about 20 hrs and the other four are at 2700 I believe. These are the readings I just got from testing the water this afternoon. I plugged the numbers in The Pool Calculator, I just follow the dosage measurements and continue monitoring the pool chemistry right? Also, I should be running all these tests everyday or limit them to a couple only and which ones? Thanks again for the help.
    FC- 4
    CC- 0.5
    pH- 6.8
    TA- 60
    CH- 250
    CYA- 70
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Did you add 70 ppm of CYA? Why so high? If it is saltwater please add that to your signature. You need to maintain chlorine based on your CYA level and the Chlorine CYA Chart. Keep it at target at all times and never let it drop below minimum or the pool will unsanitary and algae will grow. It is important to keep PH between 7.2 and 7.8 at all times. Especially in a new pool. New plaster will make PH rise so test often and learn your pool's patterns.
    estrda1's Avatar
    Nov 2009
    33
    Not sure what the pool guy added, I didn't get a chance to talk to him. According to the chart, for a reading of CYA 70 my FC should be at 5-8. With that said pool calculator has me adding 50 oz. of 10% bleach to raise the FC to 6, the median recommended range. My pool is not a salt water and was just resurfaced three days ago so I thought adding chlorine was not recommended for at least a couple of days. I just added 9 lbs. 2 Oz of 20 Mule Team Borax, pool calculator recommended 9 lbs. 15 oz to bring the pH up to 7.6 from the 6.8 it currently is. I'll test it again tomorrow and make the pH adjustments. As far as CYA, I will test it again to confirm my previous result but I'm assuming that jumping the amount it did in one day is concerning so I'll post these results in a few minutes when I do it again.
    DFW, TX
    24,450
    Here are some reference photos for the CYA test, https://www.taylortechnologies.com/C...P?ContentID=44
    It is recommended to slowly raise your FC level in a replaster. But, it is more important not to let algae get a foothold in new plaster and then have to SLAM the pool with FC levels of 28 ppm. Now that the CYA is in there the chlorine has to go in to prevent algae.
    As for reading the chlorine/CYA chart, it is not a recommended range of 5 to 8. It is recommended to maintain your FC at target level of 8 at all times. And it is required to never let FC drop below 5 or the pool will be unsanitary and algae will start to grow.
    estrda1's Avatar
    Nov 2009
    33
    Here are my readings for the past three days. I have used mainly borax and chlorine these days to get the pH and Alkalinity in check. I have been brushing it once a day and looking forward to the one week mark so I can skip day or two and give my arms a rest.My pump has been on as well the whole time and I'm just hoping that I've been doing my best to balance the pool little by little. The CYA test does get me neurotic about whether I see the black dot or not. I feel those readings may be somewhat affected by my tendency to side on the fact that I fool myself into seeing it when it may be obscured already. Any advice that you guys and gals may have would be welcomed.
    Today
    FC- 4
    CC- 0.5
    pH- 7.5
    TA- 170
    CH- 300
    CYA-90
    Wed
    FC- 5.5
    CC- 0.5
    pH- 7.2
    TA-150
    CH- 350
    CYA- 70
    Tue
    FC- 1
    CC- 0.5
    pH- 7.2
    TA- 130
    CH-250
    CYA- 85
    DFW, TX
    24,450
    If you don't raise the FC soon you are going to be brushing algae daily while you SLAM the pool. Pool School - SLAM - Shock Level And Maintain
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Yeppers get and keep that FC up please.
    CYA test-Just GLANCE in the tube. Do not stare. Fill to the bottom line (100) glance in. IF you see the dot, fill to the next line, GLANCE in. If you see the dot, fill to the next line, etc. Fill to each line until you do not see the dot when you GLANCE in. Call it that number and get the FC up to the recommended FC level.
    Kim
