Results 1 to 9 of 9
Thread: Adding salt for first time.
    Nov 2015
    Ok ok
    823
    I went ahead and plumbed in my AQR 15 SWG today. Overall no problems. I now want to add the salt, and was wondering does a guy need to pre-dissolve it or just can I dump it in? It's not wired up yet, but I want to have it all installed and the salt dissolved and then hire somebody to do the wiring, this way it will be all ready. Definitely feeling better about my pool with the Pentair Intelliflo and now the SWG. Any suggestions on how to add the salt will be greatly appreciated. If it matters, my plaster should be fully cured I would think. Thanks everybody, as usual your help is very much appreciated.
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    38,415
    Re: Adding salt for first time.
    Leave the SWG turned off. Do you have a salt water test? If so do it, and dump in the required salt ( I use solar salt from the hardware store). Spread it around the pool (let the kids play with it if you have any and the water is warm enough) It will be dissolved in less than an hour. After 24 hours you can turn on the SWG and see what salt level it is reading.
    Nov 2015
    Ok ok
    823
    I ordered the K1776 test kit which should be here probably tomorrow or the next day. It may be a week or better before I have the SWG wired up, but I wanted to salt in prior. That way it will be all plumbed in in the salt level will be ready when they hook it up. So by the sounds of things I am safe just dumping the salt in the water, no need to dissolve it prior?
    38,415
    Just dump it in
    Nov 2015
    Ok ok
    823
    10-4, thanks for confirming jblizzle
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Brushing it a little will help it dissolve faster.
    Nov 2015
    Ok ok
    823
    Thanks pooldv, my biggest concern that the salt sitting on my new plaster may be harmful. Apparently there are no worries there.
    Captain 776's Avatar
    May 2016
    Thailand
    163
    Also helps to add slowly dumping it in front of return jet
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
    Nov 2015
    Ok ok
    823
    All that fretting for nothing. I added eight bags of salt, swept it around for five minutes and it is gone. I will let it sit for a day or so and check my salt level, hopefully I can get my SWG wired in soon.
