Thread: FC doesn't want to come down
    Apr 2016
    Dayton, Ohio
    31
    My FC was 12-13 even with SWG on 20% and running pump on 1000rpm. I've left SWG off for 2 days and FC is 10 today. I added 80 oz CYA to shoot for around 60 ppm before going up to 70-80 because I got 30-40 ppm testing and don't want to overshoot. 2/3 of CYA has dissolved in skimmer.
    I haven't gotten impression that FC stays high for this long, but pool has not been used because of weather, cold and rain lately, pool is 66 degrees and no one is swimming. Solar cover is on as well, not that there is much sun lately. I assume I can test every day or two until FC is in range, but does this all sound completely normal? I'm a little paranoid here.
    Thanks
    26,000g IG, Fiberglass side/Concrete bottom, epoxy paint, Pentair IC40 SWG, Pentair Cartridge Filter 420, Pentair Intelliflow 3 HP VS pump, Pentair 120 Heat Pump, pool installed 11/2015, painted and equipment installed 4/2016. City Water.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: FC doesn't want to come down
    With the temperature relatively cold, and lack of use, it's normal for the FC to stay higher.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yep, completely normal. All good. Except the lack of !!!!
