Thread: Replace the motor of a single speed pump with dual speed?
    May 2009
    1
    I just calculated how much electricity my pump (Hayward Replacement Series 750) is using and I am displeased. It's using at least 2300 kWh per year, which is about 1/3 of my annual electricity consumption.
    It's only 3 years old, so I'm reluctant to spend the money to replace the pump with something like the Intelliflo (although I am half-considering the idea), but I'd like to use less electricity. Is it possible to replace the single speed motor with a dual speed? Is there another option I should consider?
    18,000 gal plaster IG. Sand filter. 3/4 HP single speed pump.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Replace the motor of a single speed pump with duel speed?
    You can usually find a 2 speed motor which will work in the pump but you need to make sure that you match the brake HP of the two motors (i.e. Brake HP = Label HP * Service Factor). So the new brake HP must be at least the old brake HP and can even be a little larger. Also, when shopping for the new motor look for the same frame so that it can be installed in the old pump housing.
    Mark
