Results 1 to 8 of 8
Thread: Four day vacation
    May 2016
    Downers Grove, IL
    8
    Four day vacation
    Hi Will be gone for 4 days. There is someone home to put in chemicals if need be but he wont be testing the water. I leave tomorrow. I just tested and current numbers are FC 4.5, CC .5, PH 7.7, TA 160, CYA 55. I am going to add 3.7 oz of bleach and 3 oz dry acid tonight. I usually have to add about 20 oz of bleach every other day as well as small amt of either dry acid or borax. But while I'm gone, I was thinking of having him add only 16 oz of bleach every other day til I get home, to be conservative and hopefully keep everything stable enough til I get home. The weather here will be 60s during day and 40s at night while I'm gone. Thanks for any suggestions you might have for me.
    Intex easy set vinyl pool 15 foot round 48 inch depth.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Four day vacation
    Vacation tips and tricks
    There's' some ideas.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Hey, that is a handy link. I would raise FC to shock level and lower PH to 7.2 and not let anyone touch your sparkly pool.
    May 2016
    Downers Grove, IL
    8
    Thank you that was a handy link. I just plugged in the shock level number and PH of 7.2 into poolmath and now I will make the additions of bleach and dry acid to shock the pool til I come home Thursday. Thanks so much everyone. Don't know what I'd do without this site!
    Oh and I'll leave the filter running non-stop (cheapo that came with intex pop up pool) and a cover on the pool.
    May 2016
    Downers Grove, IL
    8
    I am back from 4 day vacation. I had added enough bleach before I left to bring my FC up to shock level, hoping for a level of 22ppm based on my CYA level being 55. I tested today now that I am back from vacation and my numbers are: FC 25, CC 0, PH 7.4 but I know it's inaccurate due to high FC, TA 150 reagent turned it yellow due to high FC, CYA 55. I realize that I need my FC to drop to at least 25ppm. The next 3 days will be sunny so hopefully that will help. But I put my numbers in Poolmath and it recommends no chemical additions, however it does recommend replacing 27% of water. CYA of 55ppm is not terribly high so I thought I'd run that past someone before I actually replace 27% of water.
    My pool temp is 65 degrees. I'm in Chicago suburb and expect next 3 days to be 75-80 degrees and sunny!
    Aug 2010
    Dallas, TX
    4,052
    You can leave it at 55.
    May 2016
    Downers Grove, IL
    8
    Phew! Thanks!
    DFW, TX
    24,450
    Yep, you're numbers are fine. As soon as FC gets to 10 test PH.
