Thread: Unground pool, two skimmers... one seems clogged
    May 2014
    New Hampshire
    6
    Question Unground pool, two skimmers... one seems clogged
    I just moved to a new home and have a 30+ year old unground pool. Although the pump, filter, and salt water chlorinator are new, the pool and plumbing are not. One skimmer seems to get extraordinary amounts of suction, while the other one seems to barely have any at all. I realize that some setups are like this, as the water will take the path of least resistance, however in my case, I think it is a problem of a clog in the skimmer.
    I intentionally blocked the suction of the working skimmer suction side hoping I'd see the other skimmer suction jump up... but this did not happen... nothing did.
    I am wondering if I were to turn off the pump and close the valve to the pump (at the pump, that is), and use a hose-drain unclogger (rubber bladder that expands and then pressurizes the sealed pipe with water), if this might push whatever is in the blocked skimmer up and out by creating a pressure from underneath the suction side of the skimmer. Does this sound reasonable, or am I misunderstanding the skimmer hook up?
    I understand I can pay my pool dealer to come and use CO2, but I am hoping that this idea makes sense. Any input is appreciated.
    Paul
    New Hampshire (USA)
    3rd Pool Owner..> Still a novice... 20,000 gallons
    30,431
    Re: Unground pool, two skimmers... one seems clogged
    I am not quite following your technique but using something like a Drain King is always worth the effort. Hook one up and give it a shot.....nothing to lose.
    May 2014
    New Hampshire
    6
    I am assuming that my skimmers are connected together, and that by closing off the 'circuit' and pumping pressurized water into one skimmer, I will force it OUT the other (using the bladder). Make any sense?
    Sep 2013
    Charleston, SC
    540
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
