How to reduce reagent use during slam
For the TF 100 and the Taylor K2006 FAS/DPD chlorine test you can use either a 10 ml sample or a 25 ml sample. It is best to use the 10 ml sample, count the number of R-0871 drops, swirling between drops and when all the pink is gone multiply the number of drops by .5
You can dilute the test sample by mixing 1/2 pool water with 1/2 unchlorinated water, such as distilled water. Most tap water has small amounts of chlorine in it that would throw off the test result. I would only use this dilution when you are positive the FC is very high, since you will lose some accuracy. For example if slam level is 15 and you accidentally raised FC to 40, you may want to do a dilution test to see if you are still above 15 in a couple of hours. However if you are just trying to maintain slam level at 15 and you have been consistently needing to add 2-5 ppm every couple of hours I would not use the dilution method since you risk undershooting your FC level. When you find the FC drop is only a couple of ppm after two hours then you can try waiting 3 hours for the next test. As the pool clears the time between chlorine additions increases. You will use more reagent up front, but as long as you keep the FC at slam level the quicker the FC will start to hold and require less frequent testing.
