Thread: Liquidator float problems
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Split off of this post. JasonLion
    Quote Originally Posted by smuggs
    I called them after first trying to order replacement floats
    What happened to your floats? How can they get damaged?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Sep 2007
    Gloucester County, NJ
    141
    Re: Liquidator
    Water_man - the threaded part separated from the main part. Lesson here, I think, is to be careful of how much you tighten them when installing (or reinstalling after cleaning) them.
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    Mar 2007
    Virginia Beach
    272
    Re: Liquidator
    Smuggs, I had the same problem. I think it is partially due to age. They are not overly hard to fix. I posted a link about it here, reenforcing-the-liquidator-float-assemby-t11039.html
    As cheap as epoxy is, I went ahead an fixed my broken one and reinforced the other.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
