Thread: Replacing Pentair LN01N
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    I'm about to replace a Pentair LN01N booster pump with the same model. Is there a reason I can't use the same flex hose that connect the current pump?
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    38,305
    Re: Replacing Pentair LN01N
    No, that should be fine.
