Results 1 to 11 of 11
Thread: Pebble stuck in sheer descent
    May 2015
    Land O Lakes, FL
    527
    I can see it in the mouth is the unit. Any idea on what to do without tearing up the opening?
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Pebble stuck in sheer descent
    Quote Originally Posted by mgmoore7 View Post
    Is there room enough to slip some sidecutter pliers in and crack the pebble into smaller pieces that will wash through?
    May 2015
    Land O Lakes, FL
    527
    The opening can't be more than 3 to 4mm
    Matt
    38,268
    Your pool was built this year right? I would contact the Builder and let them fix it so that they can be responsible for any damage they cause.
    Apr 2013
    Sacramento, CA
    2,769
    This is a builder warranty issue. Call them.
    Jan 2016
    TX
    157
    I'd get a jig saw or sawzall blade and work it back and forth by hand until the pebble comes undone.
    Gunite Pool/Spa, CLI Caribbean blue crystal stone smooth, Pentair 3hp Intellifo VS, Pentair Quad DE Filter, Pentair 400k BTU Heater, KK Prowler 820, Pentair PSL4 controler with Screenlogic wifi, Inline Chlorinator, Pentair 1.5hp Spa Blower, TF-100 Test Kit w/ Speed Stir. My 2016 Pool Build
    May 2011
    Orange, TX
    66
    I agree have the builder check it. I had the same problem shortly after start up. I used a Butter knife to put behind the small pebble and pulled the pebble out. No damage occurred.
    20,500 gallon free form, 6X9 hot tub w/ spillover, 18" jumping platform w/ 3ft shear descent on chopped rock, Travertine coping, 2.5HP Hayward 2-speed filter pump, 525 Hayward Cartridge filter, 350K BTU Hayward NG Heater, 2HP Hayward water feature pump, Satin Matrix Northshore Carribbean, Jandy PDS-8 Controls
    May 2015
    Land O Lakes, FL
    527
    Thanks, I turned it on again today and there was no issue. I will monitor.
    Matt
    May 2015
    Land O Lakes, FL
    527
    Turned out to just be a small piece of foam, probably from its own packing material.
    Matt
    JoyfulNoise's Avatar
    May 2015
    13,193
    Sheer descents are supposed to have a stone trap (kind of like the particle trap on a gas line) and splinter screen in the piping leading up to it to keep debris out. Sometimes those are accessible for maintenance purposes.
    Does your setup have that?
    Matt
    May 2015
    Land O Lakes, FL
    527
    There is nothing that i am aware of
    Matt
