Thread: SWG start up.
    Apr 2016
    Highland village tx
    7
    SWG start up.
    Been following this site since I had my pool replastered 5 wks ago. The past 5 wks I've been treating my pool the TFP way and using the pool pal app with TFP configuration, my balance has been great and the last week I've started increasing CYA, I'm currently at 60ppm.
    I added salt Friday and Saturday my Aqualite is reading salt as 3100. I have t-15 cell and 10000 gallon pool. Checked my FC this morning and it's 8ppm, filter and SWG have been running 2hrs.
    What is good starting point for production %,immediately currently at 50%. What should be my target ranges, currently
    FC 8
    PH 7.4
    TA 90
    CYA 60
    CH 330
    Great site, my water has never sparkled so much. Any help will be greatly appreciated.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: SWG start up.
    Those numbers look pretty good. Here is a great summary of Pool School - Water Balance for SWGs Set your chlorine level based on CYA and the Chlorine CYA Chart, always keep it at target and don't let it drop below minimum. Use bleach to supplement if FC drops during heavy use of the pool.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: SWG start up.
    being in TX i would kick your CYA up to 80, it will help you SWG ahead of your FC usage...
    AT CYA of 80 your target FC will be 6, I like mine at 7 but it is up to you Pool School - Chlorine / CYA Chart
    Apr 2016
    Highland village tx
    7
    Re: SWG start up.
    What percentage are you guys running the cell at? I have my filter running from 7.30am to 6pm. I know the t-15 is good for upto 40000, my pool is 10000 so maybe I should run at 30% and check pool when filter turns off
    38,342
    Re: SWG start up.
    You want to test your FC right before your pump turns back on. That would be the lowest level. Staying above the minimum FC for your cya level is the most important.
