Thread: Intex sand filter timer constantly runs
    Mar 2016
    Wantagh, NY
    32
    Just hooked up my Intex 2650 sand filter pump to my pool, but 1 thing noticed is if I have in timer mode, the pump keeps running even after the set time.
    I've tried resetting the pump, but no help. So I 'm wondering if the board is N/G.
    It looks as if I will modify my set up anyway, because I don't like the fact that the GFI plug trips in the event of a power outage, so I will probably cut the cord, put on a regular plug, and put on a GFI outlet that is controlled by a timer in my house.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,542
    Re: Intex sand filter timer constantly runs
    That's what I did. It gives you more flexibility, as you can set the timer to run the pump multiple times per day, versus just once with the built in timer.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jul 2014
    Oakbank, Canada
    389
    Stupid question most likely, but you flip the switch the correct way? Mine goes 2 ways, one is for the timer, the other for full run.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Mar 2016
    Wantagh, NY
    32
    Quote Originally Posted by DarrelB View Post
    That's exactly what it was, I had mine to the on position, not timer. Thanks
    Jul 2014
    Oakbank, Canada
    389
    , easy enough boo boo
