Results 1 to 9 of 9
Thread: High CYA
    Jan 2016
    los angeles,ca
    13
    High CYA
    Hi,
    Last week when I tested the water it showed higher PH and so I added Muriatic acid. Added about half a gallon. It is a 20,000 gallon pool.
    This week when I tested the water at local store they said I have high CYA. It is at 150 ppm. Is it real high? Watched some youtube videos and they say it should be around 30 and they recommend adding Bio Active.
    Should I add Bio Active? Is it a problem having CYA that high?
    Thanks a lot.
    Re: High CYA
    Bio active is not a recommended product. I would not use it.
    150 is too high. Best is to get your own test kit and test yourself and then do a partial drain and refill as needed to lower CYA.
    How did you pH get high while the CYA also got high?
    What are all of your other readings?
    Support the site
    Jan 2016
    los angeles,ca
    13
    Re: High CYA
    My test kit was always showing high PH and I did not test for CYA back then. I should have tested for CYA before adding acid.
    My numbers are below.
    Free chlorine 8
    Total Chlorine 8
    Calcium 800
    CYA 150
    Total Alkalinity 100
    PH 7.7
    Phosphates 1500
    At this 150 level will it affect the pool equipment or it will be bad for the skin if we swim in it?
    I am hopping it will come down by itself after some time.
    If I have to drain, how much water I have to drain?
    Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: High CYA
    PH and CYA do NOT effect each other. You probably want to have your CYA at 50 or 60 at the most. So, about 2/3 drain and refill. If your pool is vinyl liner be sure to leave a foot of water in the shallow end when draining. If it is gunite check to be sure you aren't in a high water table area that could float your pool shell if your drain too much.
    The problem is that the chlorine level is set based on the CYA level and the Chlorine CYA Chart. Above 100 just requires too much chlorine to manage and the PH test does not work when FC is above 10.
    Read here for a better understanding of water chemistry, Pool School - ABCs of Pool Water Chemistry
    Also add your pool info to your signature so that we can better help you. More here, Pool School - Read This Before You Post
    EDIT: PH and CYA do NOT effect each other, left out the most important word!
    Re: High CYA
    How are you chlorinating?
    Support the site
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: High CYA
    I really think you need to do a little reading to better understand how all of these things work. Start with ABCs of Pool Water Chemistry
    Support the site
    Jan 2016
    los angeles,ca
    13
    Re: High CYA
    Using tablet in the floater.
    30 year old pool, 14x30 plaster (15k gal). DE filter. Hayward heater. HDX pool spa basic test kit.
    May 2014
    Franklin, NC
    9,193
    Re: High CYA
    Quote Originally Posted by lalapool View Post
    This is why you have high CYA. Tablets are almost half CYA.
    Support the site
    Re: High CYA
    Tabs are acidic so it doesn't make sense that your pH has been rising.
    Support the site
