Results 1 to 9 of 9
Thread: OCLT
    Jul 2008
    Seacoast, NH
    250
    OCLT
    Should I leave the filter on overnight while doing the OCLT? The SWG is off.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: OCLT
    yes, you are correct.. leave it on 24/7 until you pass the OCLT
    Almost there
    Mar 2015
    Georgia
    157
    Re: OCLT
    Quote Originally Posted by cowboycasey View Post
    Are you refering to leaving the pump on while in a SLAM and doing an OCLT or are you saying leave the pump on when you just do an OCLT? The reason I ask is it doesn't say anything about leaving the pump on when doing an OCLT here and the OP doesn't say whether or not they are in a SLAM. Pool School - Perform the Overnight FC Loss Test (OCLT)
    16k AG Vinyl Sand Filter
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: OCLT
    The OCLT is usually done to see if a SLaM is complete. Since the pump should be on 24/7 during the SLaM, it remains on during the OCLT.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2013
    Waxahachie, Tx.
    445
    Re: OCLT
    What if a SLAM has not been started and you are just trying to see if one is required. ??? Don't run your system as normal until its determined weather or not as SLAM is required?
    Then run pump 24/7 during the SLAM process?
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Mar 2015
    Georgia
    157
    Re: OCLT
    Yea that's what I was talking about, just doing an OCLT to see if a SLAM is needed. It doesn't say to run the pump to do an OCLT. You do run the pump during a SLAM which will eventually include an OCLT, but do you run the pump during a regular OCLT?
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Re: OCLT
    If not doing an OCLT as part of a SLAM I would just ensure that the pump was running at least half an hour before testing in the morning.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jun 2011
    Long Beach, CA
    2,781
    Re: OCLT
    Whenever an OCLT is being performed the pump should be running 24/7 so all variables are taken into account.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: OCLT
    I would run the pump for the duration of the OCLT test, low speed if you have it!
    Isolated Spa - 345 Gallons
