Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Cloudy water after rain - should I SLAM or just boost for a bit?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Hi All,
    I'm pretty sure I know the answer to my question, but I thought I'd confirm. Anyway, the pool has looked fantastic. Crystal clear. But after some heavy rain last night I'm dealing with some cloudy water. I can still see the drains in the deep end, but it's not right, I know that. i am pretty sure things are a bit off (chemistry) and I've just caught it before things are out of control. I know rain really shouldn't affect the water, so as to why the rain made this happen at this time, who knows.
    Anyway, I noticed FC was low this morning so I corrected things...pH was low too, it dropped. The rain? Anyway, here's this morning and just a little while ago.
    10am
    FC: 1.5
    CC: .5
    PH: 7.2
    TA: 90
    CH: 300 (pool is vinyl)
    CYA: 70
    7pm
    FC: 4.0
    CC: .5
    PH: 7.2
    TA: 90
    CYA: didn't retest
    So I added about 39 oz of washing soda to get the PH closer to 7.6 (my target) and I figure I'm borderline needing to SLAM to clear up the cloudiness. Would you agree? I only had 2 gallons of bleach on hand, so I added that, which will put my pool around 10 FC. My SLAM level is around 26-28 though. Should I bump it all the way up that high or just keep it higher than normal, but under SLAM, maybe 10-14? I have less than 1 CCs and I'm pretty sure I would hold on an OCLT but I will find out in the morning...
    Thoughts?
    Thanks
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Re: Cloudy water after rain - should I SLAM or just boost for a bit?
    I think that I would go to full slam level to catch whatever has begun to grow before it gets out of hand.
    If itís no big deal, the Slam will be over quickly.
    Support the site
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    On my way to Walmart right now!
    Jun 2014
    14,970
    It's a shame you already added that washing soda because your low pH of 7.2 was perfect for the SLAM. So if you haven't added it yet, I wouldn't. Just kick-up the FC to the SLAM level of 28. Don't forget to turn-off your SWG tonight when doing the OCLT.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Something was off on ph. My ph is spiked now to 8.2. I'm going to knock it back down with acid and then wait about 30 min and get the bleach in.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by steveg_nh View Post
    Surface aeration caused by heavy rain can drive the pH up. In a good downpour it can look like the pool is boiling.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Exactly!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Pool already looks great after only 1 day at SLAM levels. But I'm going to keep it through tomorrow, and do an OCLT tomorrow night. Easy stuff now!
    30,402
    Good work, Steve. Reading your narrative, you have a good grasp of all the TFP ideas and you are using them very well.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Thanks Dave. It really is easy when you know how it all works. I was disgusted by that cloudy water too. I think it actually made me depressed for the day! LOL.
    Richard320's Avatar
    Jan 2010
    18,967
    Definite symptom of sparklypoolitis.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Now that right there is funny (and true)!
    Just took my FC readings (averaged 3 samples out) for the OCLT. More in the morning before sun up.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Well, I didn't pass the OCLT. but that's why you do it!
    I lost 2.5 of FC overnight, so no good. Water is crystal clear and CCs 0.5, so another day or so. Keeping the FC at SLAM level another day I guess.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Drats. Failed again. My nighttime vs morning reading was off by 1.5 after averaging 4 tests.
    But, I think I'm actually passing, but wasn't careful with being consistent on drop sizes. I'm pretty sure last night I likely had the bottle of reagent at an angle, not straight up and down like I did this morning, so this morning, drops were bigger. I was able to reproduce a higher FC reading with the bottle at an angle. But I'll be safe vs sorry and will go one more day, being careful tonight.
    I just want to lower the FC as soon as I can. I know we say that even at SLAM levels vinyl liners won't be impacted by the higher chlorine levels, but I'll feel better when it's back down around 4-5.
    Jun 2014
    14,970
    So close! Also Steve, when you adjust FC tonight before bed tonight, make sure to not go too high. By that I mean don't exceed your SLAM FC level based on your CYA. I did that once and could never hold FC until I let the FC fall just a little. Good luck!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Yup, I'm holding FC just under SLAM level. SLAM is 24, I'm holding it around 21-22.
    I hope tonight is the night! It looks great though.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    All done.
    I did 3 tests this morning, and averaged them all out, since they were all within a drop of each other. Precision can be tough with the drop tests, so I like averages.
    Anyway, FC loss of 1.0, CC at 0.5, and clear as a cloudless blue sky.
    Jun 2014
    14,970
    That is one magnificent, clear-looking pool. Nice work!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Love the Church Lady!
  20. Back To Top    #20
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Just as a follow-up...your FC level was low for your CYA at 10 am originally, even for a SWG, which was probably the initiating factor. Is anything inclined to run into your pool off of your deck during hard rains? Sometimes it pays to get "onsite" in the middle of an extended downpour to see exactly what is happening to all the water. I actually have a small section of my deck that drains into my pool, but it's no worry because no ground/grass area runoff is included.
    The other thing that I thought about, but it probably wasn't the case since you had an FC user (early algae outbreak), was when the pH spiked perhaps due to the heavy rain, is that that is when calcium is more likely to precipitate and cause cloudiness. That cloudiness goes away in a day or less when pH levels are dropped to normal. And your CH isn't very high anyway. Just some musings.
    Great job getting your clear water back!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
