Results 1 to 8 of 8
Thread: 5 Year old TFT-100 test kit
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Just got another pool after drying out for 5 years and still have my TFT-100 test kit... should I chunk it and start over, or just order refills for everything... And I may need a slight bit of coaching on getting my chems right since I may be a tad rusty... LOL!!!!
    Intex 20x52 above ground pool-
    8632 gallons
    1 man 4 woman Bullfrog Hot Tub
    http://www.flickr.com/photos/pitguy3/se ... 763801706/
    ROLL TIDE!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: 5 Year old TFT-100 test kit
    Right here: TFTestkits.net Too bad you missed the pre-season sale a while back.
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Story of my life Richard... LOL!!
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Ordered!!!
    8632 gallons
    ROLL TIDE!
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    I want to start adding CYA in my pool while filling it.... do you think that test would still be close to the correct numbers? I have ordered the refill kit but trying not to waste time on the chems... Also, do pool chems go bad, like CYA??
    TIA!!
    8632 gallons
    ROLL TIDE!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    You can add the CYA now during fill and it will not hurt anything to check CYA after it is all dissolved... it might be close, never know
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by pitguy3 View Post
    TIA!!
    If you are dealing with a fresh fill, you can be confident the CYA is zero so there's no reason to even bother testing it. If it's a partial refill, I don't know. My CYA reagent has never gotten that old.
    For pool chemicals... bleach will break down into high pH salt water. Muriatic Acid has a long shelf life, longer than the plastic jugs it comes in which get brittle, so handle those like a bomb. The powders should be usable as long as they stayed dry and the lid was on the container. Chlorine powders may have lost some chlorine strength; those fumes when you open the bucket had to come from something. CYA should be fine.
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Thanks Guys!! All I have that is old isnthe CYA as I hage been using the others in the HT...
    8632 gallons
    ROLL TIDE!
