Results 1 to 9 of 9
Thread: Testing Results Data Logging
    duckvader's Avatar
    Apr 2015
    Mt. Washington, KY
    16
    Well I just opened our pool this week!!! We also switched over to SWG and I am trying to get all my levels in line and I was looking for a way to keep track of everything so I developed a website for it all. I know my levels are a little out of whack but I am following the Pool Calc recommendation and its slowly getting there. Below are some screenshots of the website running on a RaspberryPi.
    22k gal 18'x36' Rectangle In Ground Vinyl Lining
    Hayward Pump and Filter
    Hayward AquaRite T-15 SWG
    Polaris 280
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Testing Results Data Logging
    now that is really kewl you have to give some more info...
    how is it reading the temp?
    wifi?
    is this available to download
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    154
    Quote Originally Posted by cowboycasey View Post
    wifi?
    Interesting. Cowboy, there are some good smartphone apps, or you can also create a Google Form to easily input your info, which will then go to a spreadsheet. You can view it on graphs as well. Google forms are super easy to use.
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Jun 2015
    Glendale, AZ
    156
    I use a iphone app 'Pool Checks' it is free and works great for what I want.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    I downloaded Jesse's graphical pool log on TFP! It's great for keeping track of things!
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
    Jul 2014
    Manalapan, New Jersey
    98
    Quote Originally Posted by duckvader View Post
    Awesome! That would be a great app! Been using "pool care" and it's, eh, ok. All the others are not so great. Can't seem to find a good app on Android.
    23k gal in-ground gunite w/ spa/blower, Sheer descent, Jandy AquaPure SWCG, Pentair 2HP Pump x2, Raypak P-R406A-EN-C 399k BTU gas heater, Polaris 380/Polaris PB4-60 Pump, DE filter w/ separation tank
    Quote Originally Posted by friguy3 View Post
    Sent from my SM-N920V using Tapatalk
    That is pretty cool! I've have a small notebook since day one.
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Jul 2014
    Hope Mills, NC
    567
    Pool Pal for Android, it even has TFP values in the results column.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    duckvader's Avatar
    Apr 2015
    Mt. Washington, KY
    16
    wifi?
    I have a 1.5" temp probe well plumbed into my return and I have a Dallas one wire probe in there and another Dallas one wire probe zip tied to the plumbing for outside temp. It's all wifi in a sprinkler system box out by the filter and pump. It's really easy to get setup.
    Polaris 280
