Thread: What should I balance first in my case? PH or chlorine?
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Hello to all!
    I am having a hard time balancing my numbers.
    My numbers:
    FC 6.5
    CC 0
    PH 8
    TA 80
    CH 240
    CYA 80
    Temp 83
    My target FC should be 9 because of my CYA. The problem I am having is that when I add liquid chlorine (from the pool store) the PH get high. I know this is to be expected. If I then add acid to lower the PH the TA will get close to 70.
    Here is the question. In my case, as of today, should I add chlorine to raise it to 9 first? Or should I deal with the PH first and then the chlorine?
    Thank you in advance!
    Trevor
    15K gallons, Plaster, Taylor K-2006C & TF-100, DE, non SWG, Hayward TriStar VS variable pump
    Jun 2014
    15,176
    Re: What should I balance first in my case? PH or chlorine?
    Add acid now to lower pH as required to the mid 7s. TA can afford to come down a little too with that acid. Re-test in about 15-20 minutes later with pump running well to mix. Then go ahead and bump up the FC. Easy stuff. Nice pool!
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by Texas Splash View Post
    Thank you!
    I thought it was going to be more difficult.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    HA! Not at TROUBLE FREE pool! LOL
    Kim
