Thread: What did Jason mean?
    Oct 2015
    San Diego, Ca.
    646
    Jason Lion wrote this sometime back:
    "Borates won't reduce the total amount of acid you need to use but they will dramatically reduce the frequency of acid additions".
    Unfortunately, I went to public schools and don't understand that sentence.........
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: What did Jason mean?
    Borates stabilize pH rise hence the reduced frequency of adjustment. Borates stabilize pH, making it resistant to change so greater volumes of acid are needed to effect the same change as water without borates. Not as often but larger quantities when you do. Ten taps with a 2 lb hammer or one whack with a twenty pound sledge?
    Jun 2014
    15,153
    That comment just made my weekend. Bwaahaaahaa!
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    I was as mystified as the OP, but your answer makes it as clear as my water. Very nice!
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
