Thread: cya
    Mar 2016
    salisbury nc
    8
    cya
    I recently completed cpo certification. state & national.. New Cya recommendation levels are going to be less than 20.. You info is different
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: cya
    Here is an interesting thread on CPO training: Certified Pool Operator (CPO) training -- What is not taught
    Mark
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: cya
    Gosh. That's just stupid. Who determined that?
    JoyfulNoise's Avatar
    May 2015
    13,175
    Re: cya
    And those recommendation/regulations will only apply to .... commercial indoor pools. Residential outdoor pools need significantly higher CYA levels in order to operate properly or else UV photolysis of chlorine would make it impossible to keep sanitary levels of FC in place.
    Much of what is taught in CPO training is good information (although lacking in scientific rigor) but some of it is based on very old and very flawed assumptions. You would do well to read the information we have provided you in that link to fill in the gaps of CPO training.
    Matt
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,408
    Re: cya
    Our info is science based as well as daily tested by THOUSANDS of pools.
    Kim
