Thread: Do I need to ADD BORIC ACID again this year if I already added it last year???
    Jul 2010
    North Bergen, NJ
    172
    Just a quick question, I added approx 25lb of Boric Acid to my pool last year (14x26 in ground vinyl approx 9500-10,500). I closed it at the end of the summer here in NJ. I just reopened the pool (it was covered with a Loop Lock Mesh cover) and shocked and cleared up my pool a few days now. So Im wondering if I need to now re add Boric Acid again?
    Also how can I measure the PPM for Borates in my pool if I need to know the levels?
    thanks all!
    Design 14x26 (10,000 gal) in ground vinyl pool, 2 Wide Mouth Skimmers, 3 Returns
    Equip 3.0 HP Pentair VS pump motor, 48 FNS Plus DE filter, IC20 SWCG, 400Btu NG Heater
    Extras Easy Touch Automation, Pentair LED Lite, Kreepy Krawl Racer pressure cleaner
    Water pH 7.5, Total Alk 90, Free Cl 4.5, Combine Cl 0.25, CYA 65, CH 275, Salt 4100ppm, Borates (Boric Acid) 50ppm
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Do I need to ADD BORIC ACID again this year if I already added it last year???
    It's probably still in there but to check it here is the test. TFTestkits.net
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    JoyfulNoise's Avatar
    May 2015
    13,264
    Both Hach and LaMotte make test strips for borates (both available on Amazon). Not the best in terms of precision values but it will tell you what ball park you're in. Only water exchange lowers borates.
    Matt
    Jul 2010
    North Bergen, NJ
    172
    thanks all for your help...I purchased the Borates test kit and found my Borates to be approx 50ppm so I think I will not add anything. I will say these strips do leave some ambiguity as the colors all do look very similar
