Hey everyone. I recently converted to a salt water pool and my stabilizer is at 140 and both chlorine #'s are above 10. I'm still in the process of opening it and backwashing/vacuuming a decent bit so I'm not worried about draining just yet, but I don't have a bottom drain anymore either (the liner installer talked me into capping it). I can vacuum to waste though, which I guess would work for going below the skimmer if I close the 2nd drain.
So my question is how high I can leave the stabilizer/total chlorine and still be okay for comfortable swimming? Also, it's only in the 80's in my area; should I just give the sun some time to work before trying to drain large amounts of water? All my other numbers are perfect, by the way, and the pool is about 95% crystal clear with only a little cloudiness in the deepest areas.
