Thread: Adding stabalizer
    Jun 2015
    Estill Springs, TN
    14
    Adding stabalizer
    I am refilling my pool....can I put the stabalizer in a sock and tie it under the running hose BEFORE the pump can be turned on?
    10,470 gallons @ 90%; 22' x 52" Intex Ultra Frame; cartridge filter 633T; May 2015
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Adding stabalizer
    Sure, that will work fine.
    Jun 2015
    Estill Springs, TN
    14
    Thanks!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You just want to make sure it is not sitting in contact with the pool
    Jun 2015
    Estill Springs, TN
    14
    Okay..fixed that..lol
