Results 1 to 16 of 16
Thread: Pool guy turned me down, need advice
    May 2016
    Oklahoma city
    4
    A maintenance guy wasn't interested in maintaining my pool, so I've turned to this website and need some advice. I purchased the Taylor kit and ran the tests. Results are as follows: CYA = 100 (or more), FC=2, CC=.5, PH=7.5, TA=120. The pool was completed in August of 2014 and I have been maintaining it since. I thought the salt was the only thing I needed to be concerned with, but then had my water tested and the ph was high. I've had to add muratic acid quite a bit over the last year to get the ph within range. The water looks pretty clear, but there is a definite chemical smell that has led me to believe something isn't right. Any advice would be appreciated.
    SWG pool, 23,400 gallons
    in-ground plaster/ rectangular shape/ Cartridge filter/ pentair equipment
    just ordered test equipment- think it is Taylor
    filled using city water, not expensive in OKC
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Pool guy turned me down, need advice
    Welcome!
    To get a better handle on the CYA level, you can do a 50% dilution and then test again. What you do is collect some water from your pool, add in an equal amount of tap water. Use that as the pool water for the CYA test. Then just double the number. So if after you test with the diluted water, you get 70, then your actual number is 140.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Well for sure I would do a partial drain to get the CYA level down.
    I would do a 50/50 dilution and retest the CYA as the test vial only goes to 100, it could be higher.
    PH creeping up is normal with an SWG. As you add acid, the TA drops too, and eventually the creeping up should slow down once the TA is closer to 70-80. But this assumes no water replacement.
    Figure out the CYA issue before you do any other chemistry adjusting.
    Jynx
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    It's normal with a SWG to have a rising pH, but you could try lowering the TA a little, that has been shown to help slow the pH rise.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    You'll do better on your own anyway. I'm curious why he turned you down, but no matter. If you have high TA and fill water you'll always have to fight both with acid additions. How much depends on how high, but if they aren't too bad, you may do much less adding once you get the pool TA down in the 60 range. Your SWG will do better there as well. What is your pool and incoming Calcium level?
    If I may, please let me suggest doing a lot f reading in Pool School. Check out the ABCs first, and dig into the rest as you can digest it. Ask questions if you need too, we are always here to help. It's a guess but if the chemical smell you mention could be Combined Chlorine, but please describe what it smells like.
    Essential Links:
    May 2016
    Oklahoma city
    4
    so I retested the CYA diluting half with tap water and it still looks like it's about 100. The pool guy didn't want to maintain our pool because I have 2 young boys and a big pecan tree that is close to it. I'm thinking the smell is chlorine related. Last summer our bathing suits were also degrading/ getting discolored.
    Will the CYA come down over time? Should I just try to lower the TA at this point? I have the SWG at 60% ouput as well.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have to wonder how the CYA got so high with an SWG pool, have you been manually adding stabilized chlorine products (dichlor or trichlor) or was too much stabilizer added to the pool at initial start up?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    The bad news is, you are going to have to drain at least half your pool water. Refill, then test CYA again. Considering your current level, it may take more than one drain and refill.
    11,969
    Quote Originally Posted by pabeader View Post
    Ditto.
    I've seen the degradation in pools with high CYA. There seems to be a connection....
    Jun 2013
    South Florida
    118
    Two young boys and a tree? Lol, he should see mine. A black lab that swims non stop, a torn up yard with grass and dirt, palm trees everywhere. And yet I still keep a clean pool with only one or two checks a week. Sounds like your guy didn't want to put in any effort at all.
    No worries, just take care of it yourself. Start with a 50% drain and refill and see how your CYA level pans out. After that, it will be a piece of cake.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    May 2016
    Oklahoma city
    4
    ok, so I drained half the pool and re-filled. I added salt to get the ppm up to 3,400 which is what is recommended for my SWG. I added 3- 1lb bags of dichlor "shock", and some muratic acid to get the ph down to 7.5. I waited a few days and re-tested the water and have the following results:
    CYA= 40
    FC = 5.5
    CC = .5
    PH=8.0
    TA=90
    CH=130
    Should I add more dichlor 1lb bags of shock aka stabilizer to raise the CYA to 70? Should I lower the percentage of my SWG to reduce the FC, or reduce the pump time? Just trying to figure out where to go from here.
    Aug 2014
    Houston tx
    2,524
    Did you put your numbers into Pool Math? It's a great tool to use. http://www.troublefreepool.com/calc.html
    (I'm not sure why the link doesn't say Pool Math)
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Every time you add dichlor you are increasing your CYA. If you need more FC than your SWG is producing just use bleach, using the calculator above.
    I see you have a SWG and are raising CYA on purpose.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jan 2014
    Buckeye AZ
    807
    The powdered shocks may take a few days to register in the CYA test. Make sure to test your CYA again in a few days.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Yup, take it slow on the CYA raise. Make sure everything is registering on the test before you move to raise it again.
    Support the site
    May 2015
    Carbondale, PA
    17
    My pool is not SWG, but my hot tub is. Creeping PH has been the one thing that has plagued me since I got it. I discovered that keeping my TA around 60 keeps my PH pretty stable. That took a lot of testing and adjusting to figure out the magic number for me.
    27 foot round 4ft deep AG vinyl. Hayward Sand Filter.
    Dr. Wellness Lifestyle x-12 spa.
