Thread: Fine tuning salt settings
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I understand the following:
    - if I increase the output on the salt system from 50% to 60%, then the salt system will remain active for 10% more during the run time
    - if I increase the pump run time, then the salt system will create chlorine for that extra amount of time relative to it's output percentage
    Question: What happens when I leave output the same and run time the same, but I increase pump speed? More volume of water is moved through the salt cell, but will the cell actually produce any more chlorine?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Fine tuning salt settings
    The output is independent of flow rate subject to minimum flow rate limits.
    Matt
