Thread: Getting CYA level up
    Apr 2016
    Dayton, Ohio
    31
    First, is there an expiration for CYA? I got a 25 pound pale and will use around 7 pounds this year.
    I put 5 pounds in a muslin bag I bought to brew beer and threw it in skimmer. Bag is more porous than a tube sock, but there isn't a tube sock to be had in our house or 6. A little bit of the granules ended up in bottom of pool and I brushed it out of corner but assume it won't dissolve for couple days. Any worry about being on epoxy, maybe a 1/2 cup or less total came through bag when I wet it in front of return?
    Also I can see small amount of granules in pump basket and assume that's ok and should get caught in filter until dissolves there.
    Does the acid going through equipment at higher concentration directly from skimmer pose any issue?
    Thanks
    26,000g IG, Fiberglass side/Concrete bottom, epoxy paint, Pentair IC40 SWG, Pentair Cartridge Filter 420, Pentair Intelliflow 3 HP VS pump, Pentair 120 Heat Pump, pool installed 11/2015, painted and equipment installed 4/2016. City Water.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Getting CYA level up
    Its not as acidic as muratic acid so no. Make sure the filter stays running for 48 hours while it dissolves. Can you vacuum that spill up?
    I'm not aware of an expiration, if stored properly. You'll know when you test if its still got its muscle...
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,505
    CYA doesn't go bad if it is kept in a closed dry container.
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
