Thread: Broken MTA in Filter Head - Help???
    May 2016
    Littleton, CO
    1
    The MTA/male pvc fitting on the pool filter head broke flush with the filter intake. It was glued and I need to remove this glued, threaded pvc fitting without damaging the filter head. Any Advise!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Broken MTA in Filter Head - Help???
    Welcome!
    Probably that's threaded and not glued in, except maybe with hardened teflon paste. That broken piece looks like a threaded adaptor.
    Get a chisel or a trowel or some other piece of thin hard metal and heat it up and push it into the pipe section so you've got a bite. Then try turning it with a crescent wrench and see if it will unscrew.
    The other option is to get an oversize coupling and a reducer and glue the coupling to the outside of the valve. Usually they're dual-sized; 1.5 pipe internally, 2" pipe externally.
