Thread: Wiping Tip of Bottle After Each Drop on TA Test
    May 2016
    Atlanta, GA
    89
    I just got the TF-100 testing kit. When testing Alkalinity is says to "add R-0009 one drop at a time, swirling between each drop. Wipe the tip of the bottle after every drop with a damp cloth."
    I am curious why this is done as it is not specified in any other test and how important it is to do?
    It's pretty annoying when you are trying to add a drop and swirl after each drop.
    I know...first world problems. But it's bugging me so I thought I would ask.
    KG
    14.5'x32' irregular shape Pebble Tec SWG pool; 12,000 gal; Purex Triton Tagelus Sand Filter; Pentair IntelliPh Ph Controller
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Wiping Tip of Bottle After Each Drop on TA Test
    Sometimes a static electric charge can build up on the R-0009 dropper bottle tip, causing the drops to be smaller than usual and making the test read higher than actual. This is usually only a problem for the first couple tests, when the bottle is new. Don't ask me why. If ever you see your TA jump from where you think it should be, go back to the wiping.
    As an aside, a speedstir does the swirling for you, so wiping the tip would be no hardship at all. Ask for one for Father's Day or something.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    when you first receive your kit, for some reason the R-0009 has some static electricity going on and if not wiped off it can give you a false high reading, after a few weeks it should be good to not wipe the tip.. if you look really close you can see the drop is just slightly smaller than other drops..
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    I was having so much trouble with the static buildup on my bottle giving me quick, small drops that I started wiping the whole top half of the bottle with a wet paper towel between drops. Otherwise, by just wiping the tip I could tell the drops were smaller than they should be, but for the life of me, I couldn't get them to change by just wiping the tip. I'm just glad I found a way to do the test more accurately now, so the wiping doesn't bother me. But I do have the speedstir, so that helps.
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
