Thread: Cyanuric Acid reagents
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    Hi everyone!
    First post.
    I have a quick question about cyanuric acid reagent. Are all reagents the same, e.g. can I buy Taylor cyanuric acid reagent and use it with my HTH test kit? I bought a 6-way HTH test kit and it only came with enough CYA reagent to do three tests, and the store (Wal-Mart) doesn't carry the refills for it. I see that I can buy Taylor reagent in large quantities on-line, so I figured I would order that so I can make use of the kit I have.
    We have a pool stores around here where I could probably buy hth reagent, but their hours of operation don't jive well with my work hours, so it's hard to get to it.
    Thanks!
    21,000 Gallon IG Plaster with Spillover Spa (Built in 1978) | 48 sq/ft Hayward DE Filter | 3.0 HP Pentair Variable Speed Pump | Hayward H250FDN Heater| 8 Gallon Liquidator | Taylor K-2005 | Taylor FAS-DPD Chlorine Test | Taylor "SpeedStir"
    Re: Cyanuric Acid reagents
    Not all CYA reagents are the same. However, the HTH CYA test reagent is compatible with the Taylor CYA reagent.
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    Thank you!
