Results 1 to 7 of 7
Thread: Cloudy a week after AA treatment
    May 2011
    Harrisburg, NC
    13
    Hello from long time lurker and thanks in advance for the help.
    Opened the pool this year with the TFP methods and have been very happy/trouble free until yesterday.
    I had a lot of iron staining (well water) so I did an AA treatment last weekend. Very happy with the results and have been slowly bringing the FC levels back. Pool was perfectly clear and looked great.
    Thursday night we had about 1.5" of rain. Friday evening the water was hazy. Tested FC and it was down to 1 from 2. Added CL up to 3.
    Tested this morning and FC seems to have maintained overnight. Here are full test results from this morning.
    PH 7.2
    FC 3.0
    CC 0.0 (maybe 0.5)
    CH 100
    TA 50
    CYA 40 (was going to raise this today but waiting for advice first)
    I added some DE to filter to see if that helps.
    Ideas?
    In Ground 20x40 Grecian; 3.5 to 8 depth; 33,000 gallons, Vinyl Liner, Hayward On-Command Automation, EcoStar 3400VSP Pump, Pentair Sand Filter, Aquarite SWG, Diving Board, Slide, Saving for Robot :)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Cloudy a week after AA treatment
    Welcome to TFP
    You probably have the beginning of algae... when your FC went to 1 it allowed algae to take hold... My advice..
    turn off SWG
    Bring your pool to SLAM level of 12, using bleach/liquid chlorine, keep it there by adding and checking fc as much as possible using poolmath above..
    once you have passed OCLT let you FC drop down below 10
    check all levels and adjust to recommended levels for SWG
    add CYA to 80
    turn SWG back on
    keep FC level above 4 at all times and target for 6 FC
    All the links for the SLAM, OCLT and recommended levels are below in my sig
    I hope this helps
    May 2011
    Harrisburg, NC
    13
    Thanks.
    SWG off.
    FC up to 12
    We'll see what happens.
    May 2011
    Harrisburg, NC
    13
    Hmm FC back down to 10. Definitely something in there.
    Added Cl for FC back to 12
    Going to go stock up more chlorine jugs. Walmart here we come.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Eekkks. Slamming so soon after an AA treatment could cause the stains to reappear. Be sure to have lots of sequesterant on hand. Did you use the Polyquat 60 algaecide when you started the process? It's not too late to correct this but just be aware and have something for the iron on hand.
    Also is it sunny where you are today? Don't attribute the 2ppm loss to something in the water. It may be, it may be UV rays too. Thats why we do the OCLT at night...
    May 2011
    Harrisburg, NC
    13
    Quote Originally Posted by frustratedpoolmom View Post
    Did not do the algaecide but looks like I should have.
    I was a little worried about re-stain so slow on the FC increase this week. Yes just added more sequestratant this morning.
    11,969
    Ok stay the course...do an OCLT tonight.... Next time, Polyquat!
