Thread: In Line Chlorinator
    May 2014
    Clinton,Iowa
    42
    In Line Chlorinator
    What are the pros and cons of the In Line Chlorinator for the tabs? Thinking about adding one this year.
    28' Above Ground Pool, 20,000 Gallons
    Sand Filter"
    Model #AC16985
    Pool built in July 2012
    Clinton, Iowa
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: In Line Chlorinator
    about the only thing that is good with them is if you are going on vacation, but I would just buy a couple floating tab dispenser's and call it a day (for vacation)
    Amazon.com : Swimline 8720 Large Capacity Floating Chlorine Dispenser : Swimming Pool Chlorine : Patio, Lawn Garden
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,968
    Pro: You can leave town and use trichlor to chlorinate and the inline feeder allows you to use a cover, too. A floater will get in the way.
    Con... here's an essay I wrote a couple years ago.
    We'll take a 16000 gallon pool, because that's what I have. On a fresh fill, prominent national pool chain recommends 2.5 pounds pf stabilizer per 10,000 gallons, which works out nicely to 4 pounds which brings CYA to 30.
    With an average loss of 2 PPM/Day or 14 ppm/week, I'll have added 8.6 PPM/CYA if I used trichlor pucks perfectly. And they recommend a weekly "shock" of dichlor between 5 and 10 FC.... 2-3 oz per 10,000 gallons. Split the difference; I'll add 4 oz. CYA went up another .9.
    So..by the end of week one, I have added 9.5 more CYA. It is now 39.5. Mimimum FC for that is 3, so I'm probably okay.
    Week two, up to 49 CYA.
    Week three, 58.5. Minimum FC should be 5, but they recommend 3 as ideal, so the pool looks a bit hazy. So I'll toss in a little extra dichlor "shock" to jack FC up to 10. Which adds another 6.4 CYA. Keeping count? We're up to 64.9 now.
    That caught the algae just in time.. we had two weeks of good luck. A steady diet of pucks and 4 oz. "shock" each week only added another 19, up to 73.9 now.
    Week 6 it started looking funky, so we "shocked"it once again. CYA is up to 99.3. But minimum FC to keep algae at bay is 8, and we're still holding things to 3, because prominent national chain's preprinted sheet shows that as ideal. So algae got a toehold and the pool has a bit of a tint. So we throw two whole bags of dichlor in which jacks it another 7.6. By the time week 7 is over, we're at 116.4, because we had pucks in the floater the whole time.
    So...in 7 weeks, from 30 to 116.4. Let's say there are no more algae outbreaks because they sold me a huge bucket of phos-free and another of yellow-out monopersulfate "shock" Nothing but the pucks and the extra 4 oz of dichlor "shock" weekly. So the next 7 weeks added 66.5, which brings the total to 182.9 CYA.
    Now if we didn't understand this and things looked a bit hazy, we might throw an extra puck or two in the floater every couple weeks, which will drive it over 200 easily.
    If you don't want to hassle with manually dopsing the pool, switch to a SWG system, or get a liquidator or a stenner pump. Use the search box on those terms and you'll find plenty of information to overwhelm and confuse you!
